It is currently Sun May 24, 2026 4:56 pm
PostPosted: Tue Jul 23, 2024 2:53 pm
Old original H14 mast heads are hard to find. I've seen references to fitting a twin sheave comp mast head on a regular all aluminum H14 mast. The only suggestion was that you had to use the comp tip halyard with the new mast head. Does anyone know if this is doable or has done it? Any insight would be much appreciated. David J
PostPosted: Tue Jul 23, 2024 3:31 pm
The H14 Mast head is not a prefect fit with the aluminum extrusion, but it could work. I have not seen that done. On the 16 it is way more straight forward / good fit.
PostPosted: Wed Jul 24, 2024 5:46 am
Not sure about the H14, but on the H16 I believe the halyard hook would have to be relocated as well due to a different distance between the mainsail head shackle and the nicropress fitting.
If your issue is only with the masthead sheeve, some folks have apparently been 3D printing those for the old H16s, so you may want to check into that.
Jerome Vaughan
Hobie 16
PostPosted: Wed Jul 24, 2024 7:11 pm
It fit perfectly when I installed it on an 80s vintage black anodized mast, and the halyard hook is the same spot.
It works real well I am using it on my boat (H14)
Mike Hensel
'86 Hobie 18, '93 Hobie 14, '80 Hobie 14(restso in progress)
Wind in your sails, water in your shoes, great day!
PostPosted: Wed Jul 24, 2024 7:19 pm
That's good news Mike, Did you have to cut off the tail that would stick down into the mast?, or did it fit on the aluminum section and just require riveting in place? Much obliged for any additional details or photos. David
PostPosted: Fri Jul 26, 2024 7:01 am
Slides right in.
I’ll try and get the pictures to work post
Mike Hensel
