It is currently Sat Aug 08, 2026 7:26 pm
PostPosted: Wed Aug 27, 2014 7:56 am
I have a badly cracked wing tube on my Hobie 17. One of the wing caps was missing for the wing going into that tube. I located the cap at the bottom of the tube. It is jammed in place (probibly from the wing being inserted after the cap came off).
Any ideas of a good way to get the cap out?
Once I get the cap out and the tube(s) repaired, I plan to put schedule 10 - 1 1/4" aluminum pipe inside the wings "pipes" to strengthen them (36" pieces available fro McMaster-Carr at about $35 each). I have received these pipes and they fit. I will use a little epoxie so they don't move.
Has anyone filled the wing "pipes" with foam to insure positive floatation?
If so what did you use and how well did it work?
PostPosted: Wed Aug 27, 2014 9:25 am
A wire hanger with a very short 90° hook bent on one end works well for fishing an end cap out of the wing tube. Try to snag one of the rivet holes in the end cap.
Why do you feel the need to strengthen the wing pipes? They're plenty strong on their own, unless you've welded them (destroys the heat treatment). Making them stronger makes the wing tube in the hull the weak point. It's much easier to fix a broken wing (replace) than a broken wing tube. Also, the end of the pipe inside the wing tube creates a hard point (break on the dotted line), unless you create "fingers" on the end of the pipe to spread out the transition.
Positive flotation? The wings should never be on their own in the water. Shooting foam in them just adds weight and a potential source of trapped water = corrosion. Bad idea.
PostPosted: Wed Aug 27, 2014 12:47 pm
I'll try the coat hanger but the cap is jammed in so I may need and alternate if that doesn't work.
Boat is a 1986, wings have not been welded but I notices some corrosion inside the wing "pipes" (actually found one pinhole) so I plan to proceed with inserting the aliminum pipe. Good idea about making fingers for the transition - Thanks.
Foam trapping water in the wing makes sense, so I'll pass on doing that
