It is currently Sat Aug 08, 2026 9:20 pm
 Post subject: 17 turtle turtling
PostPosted: Thu May 25, 2017 4:13 pm
After nearly getting scammed off e-bay, I actually scored a 17 sport an hour from home on C-list. Pretty scary because dude insisted on cash, so, after some research, I did the deal in the Police parking lot (at his suggestion). Question: How likely is the sport to turtle in a capsize? My home waters of lake erie off cleveland don't get deeper than 25' till a mile or so offshore, so most sailing will be in peril of a turtle. Should I get a mast bobby, or is the comp tip bouyant enough? Also, it seems a mast bobby would add weight and make it harder to right solo?--scow
Hobie 17 Newbie
 Post subject: Re: 17 turtle turtling
PostPosted: Thu May 25, 2017 4:53 pm
It won't typically turtle quickly, so if you can get the mast upwind and / or hang on the righting line... you can prevent it.
PostPosted: Fri Jul 14, 2017 8:52 am
Make sure and check your mast for leaks. I found out just how quickly a 18 will turtle will a leaky comptip. It's as simple as submerging the mast and looking for bubbles.
Sent from my SAMSUNG-SM-G920A using Tapatalk
'95 H16 sail #101148
'89 H18 SX/ sail #1053 w/ Yellow hulls
