It is currently Sat Aug 08, 2026 11:04 pm
 Post subject: tramp repair
PostPosted: Wed May 02, 2007 11:34 am
I have small (1/2") cut through my solid vinil tramp. I have piece of same material I would like to glue over (or from both sides). What will be best glue to use? Contact cement?
Thanks 8)
PostPosted: Thu May 03, 2007 11:45 am
Contact cement worked well in my repair of the vinyl tramp on my H16. Vinyl cement would probabily work also. In my repair I glued the patch to the undersid of the tramp then reinforced the patch with stiching using a sewing all, that would minimize the 'patch look'. :wink:
PostPosted: Wed May 09, 2007 6:45 pm
Not familiar with sewing all. What does it mean? :roll:
PostPosted: Thu May 10, 2007 3:52 am
all = awl
A tool that looks like a short ice pick used for punching needle holes through heavy material (as opposed to pushing a needle through).
PostPosted: Fri May 11, 2007 1:37 pm
Thanks MBounds, that is exactly what I ment and the awl pictured happens to be the same type I used. :lol:
PostPosted: Fri May 11, 2007 6:05 pm
An auto upholstry shop would probably sew it on for you for pretty cheap. I replaced both of the hiking straps on my 16 with old seat belts and they did it for 20 bucks. I would imagine that a single patch would be considerably less. That is, if you don't have an awl or if you don't want to spend your time/energy.
James
86' Redline Hobie 16
Sail # 76909
