It is currently Sat Aug 08, 2026 10:39 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Sep 05, 2007 12:23 pm
Mbounds
No - it's not a class legal sail. You can buy the class logo as a sticker and put it on anything
Correct, it is not class legal and you can put it on anything, like a square top sail that out performs the stock sail and will most likely out last it. I got only 4 seasons out of my stock sail before it started to delaminate and tear along the luff. I sailed with the repair for another season while researching sails. Since Hobie refuses to update their sail design and materials (probabily due to the single class racing), I had to go aftermarket to get the performance I desired and leave the class racers in my wake. 8)
PostPosted: Wed Sep 05, 2007 1:28 pm
The Hobie 17 is an ISAF International Class. Hobie does not control the sail design or the materials. The class, with oversight approval from ISAF does. It's not going to change anytime soon.
PostPosted: Wed Sep 05, 2007 4:09 pm
Ya, I figured it was something like that. Too bad. :cry:
 Post subject: Race Portsmouth
PostPosted: Wed Sep 05, 2007 4:14 pm
Fastcat:
If you nail your starts, you WILL do real good. 17 has real good PN numbers.
Doug
PostPosted: Mon Oct 27, 2008 5:13 pm
Well I've had the Whirlwind square top for a couple of seasons now with about 60 outings and it appears to be holding up well and keeping its shape. I really like the way the square top twists off during puffs. The only modification I’ve done is to replace the bottom baton that came with the sail with a stock Hobie baton which is a bit stiffer and longer. The original baton stopped about 4 inches short of the luff and put a slight cup in the bottom of the luff when tensioned. I removed the last rivet from the 3 hole plate that hooks the sail to the boomlet and use the resulting rivet hole to secure the baton.
