It is currently Sun Aug 09, 2026 1:12 am
PostPosted: Tue May 23, 2006 5:41 am
I want to outfit my Hobie 17SE (1993) with at spinnaker (an old tiger-spinnaker). Most of the spinnaker-kit will be outfitted like the Hobie 16. I don’t have a jib, only the original forestay/bridle. I’m planning to connect the spinnaker-pole to the two bridle bearings (bridle adjuster) on the hulls, and a small V-line to the forestay/bridle, to keep the pole lifted.
Is the windward hull strong enough to take the main-load from the pole/spinnaker tack?
Can I damage the hull before capsizing?
Regards,
Torben Houborg
 Post subject: Be careful
PostPosted: Tue May 23, 2006 8:33 am
Torben:
When I was looking a to get other sails for my 17, I looked at a Hooter. I was told it would break the computip mast. That is why I went with the Hobie 17 Sport jib setup and had a 190 sq ft reacher made. I have really enjoyed it. Matt could probably advise you better, but be careful not to break your mast.
Doug
 Post subject: Re: Be careful
PostPosted: Tue May 23, 2006 9:40 am
Hi Doug,
Thanks for the input. My mast is all aluminium; I hope it is stronger than the computip mast. The Tiger mast is 9 meters, and the Hobie 17 mast is only 8½, so I have to lift the halyard a little. I know the Tiger spinnaker is big, I properly wont use en in heavy weather ;-).
Torben
PostPosted: Tue Dec 05, 2006 11:14 am
Hi Torben!
Im a Swede with a 1987 HC17 LE Turbo (as they where called i Europe, with alu-mast, furled jib, and boom). I have had thoughts of getting a genaker (spinaker) just like the Tiger and I became very curious when I read your message. How did this turn out for you? Did you get a spinaker or did you go for a Reacher (do not fully understand the difference)?
Best Regards Hans
Regards,
Torben Houborg
Sails a 1987 HC 17 with new main and jib from 2006
PostPosted: Wed Dec 06, 2006 2:41 am
Hi Hans,
Sorry, I haven't made any progress – nothing new. I’ve got an old windsurfer mast for pool – that’s all.
Regards.
Torben
