It is currently Sat Aug 08, 2026 3:42 pm
PostPosted: Mon Aug 17, 2015 6:41 pm
After I set my mast up Saturday I noticed the nut fell off inside the spreader bar. This nut holds the cable to the end cap of the spreader bar. The nut on the side that did not fall off is self locking, though it was loose also. To get to it, the rubber end cap has to come off the end of the bar to see the Phillips head of the screw the nut is screwed to. To get the new self locking nut on and tight I had to take off the mental end cap off of the spreader bar. I replaced the nuts on both sides to be on the safe side. Fortunately I noticed mine while the boat was still on the trailer.
Just wanted to notify the other Hobie 17 Sport owners to inspect theirs before they have a surprise failure. The nut can be seen from the cutout underneath the spreader bar where the metal rod comes through.
Sail on!
1977 Hobie 16
1992 Hobie 17 Sport
PostPosted: Mon Aug 17, 2015 11:09 pm
It would be worth putting some loctite on there too. Those self locking nuts are great but the loctite adds that extra safety.
2007 Hobie 16 - 'Slingshot'
1996 Hobie 18 - 'Onrails'
Hobie Bravo - 'Hobie Bites'
PostPosted: Fri Feb 12, 2016 10:30 pm
Yes this has been a problem over the years. Fortunately if the nut comes off, as it did once to me, you don't get demasted, but you do bung up the end of the spreader channels a bit. Now I use both a lock nut and lock tight, so far so good.
PostPosted: Thu Mar 17, 2016 5:27 am
:D
PostPosted: Sat May 07, 2016 1:55 pm
Does anyone know the size of the bolt and nut? I have one nut that fell off. Thanks
