It is currently Sat Aug 08, 2026 5:47 pm
PostPosted: Mon Oct 12, 2015 4:27 pm
I have a 1998 Hobie 17 Sport. I need a tiller arm for the right rudder assembly. However, my style of tiller arm does not match what is in the parts manuals for the Hobie 17 Sport. My tiller arms seem to match what is on the Miracle 20, with a retainer clip attached to a shock cord that clips on a pin to secure it to the tiller crossbar. The part number given for the tiller arm for the Miracle 20 is 40380011. Does anyone know if this is the part I need? Any idea on where I can get one?
Thanks much!
PostPosted: Tue Oct 13, 2015 3:16 pm
Tiller arms are only a tube of aluminum... no fittings, so you want the one shown in the parts guide for the 17. You would then drill and install on the casting and then drill and install the tiller end fittings for the type you had. Parts sold separately.
Tiller Arm 50321111 Image
Tiller end fittings shown on the H20 page (support area / part guide) or the H16 page 51 in the current catalog & support area / part guide.
Catalog: http://cdn.hobiecat.com/digital_assets/87367230_International_Sail_March_2016_Web.pdf
PostPosted: Wed Oct 14, 2015 1:51 pm
Thank you, Matt. Most helpful.
PostPosted: Thu Oct 15, 2015 4:15 pm
I am also confused on what traveler car I need for the main. I think it's H159, but the description doesn't seem to match. Mine has 11 "axles" with "wheels" on each end of the axle. I appreciate any help!
PostPosted: Thu Oct 15, 2015 5:02 pm
That is a standard traveler car from Hobie Cat. Either #105 (stainless wheels)
or #111 Larger Brass Wheels
You can replace just the lower bearing part as well. #106
or #112
PostPosted: Fri Oct 16, 2015 7:29 am
Thanks again, Matt. Makes sense. I was thinking I had to pick the right one - actually, I could pick any of them. I really appreciate the help!
PostPosted: Fri Oct 16, 2015 8:30 am
You would have to have the newer deeper track to use the Brass wheel version.
