It is currently Thu Aug 13, 2026 4:12 am
PostPosted: Mon Sep 28, 2015 9:07 pm
My 1988 turbo has the mast raked pretty far. I can shorten the blocks even more and achieve more rake, however, the mast base will barely hit the stops on the mast step so that the mast will over rotate.
Is there an updated mast step for the H14 similar to the H16 that allows more severe rake? I see part number 10170011 in the catalog, is this part updated over what I have on my 1988? Finally, it says undrilled, what does that mean?
PostPosted: Tue Sep 29, 2015 3:18 pm
Drilled means there's a threaded hole for the dolphin striker rod on the H16 (and factory H14 turbo, I presume). I'm not familiar with the add-on or aftermarket turbo parts. Undrilled is for the stock (non-turbo) H14 (no striker). Otherwise, I'm certain they are the same part on the 14 and 16.
Jerome Vaughan
Hobie 16
PostPosted: Tue Sep 29, 2015 10:57 pm
That's good information. I have the factory turbo so I need drilled.
I see in the parts listing details in the back, "20200011 Mast Step, H14/16 Black".
The diagram shows "H16 black mast step 20200011" which is why I was confused since it didn't mention 14.
Looks like 20200011 is what I need.
