It is currently Thu Sep 10, 2026 1:42 am
 Post subject: Removing boom end cap
PostPosted: Fri Jul 31, 2009 12:27 pm
Hi
I want to remove the boom end cap, mast end. But it seems to be stuck fast, despite drilling out the rivets. Any suggestion in how to remove it?
Cheers
PostPosted: Fri Jul 31, 2009 1:06 pm
Large blade screw driver or punch inserted in the luff track... against a ridge of the casting and hammer out. The get bound up by salt or corrosion.
PostPosted: Fri Jul 31, 2009 1:40 pm
I can't do that, because at the mast end, the cap is flush to the boom extrusion, and does not extend up to the track. Its a bit of an issue.
Cheers
PostPosted: Fri Jul 31, 2009 1:42 pm
I still think you can get a bite of the cap using a blade driver or punch. Just get an angle on it and WACK it.
PostPosted: Sun Aug 02, 2009 7:11 am
OK, hammering did not work. So I tied the boom to a tree, put a loop of rope though the gooseneck fitting on the end cap, which connected to the tow ball on the car and drove off. With a loud noise, out came the end cap.
PostPosted: Mon Aug 03, 2009 9:05 am
Good work! The tree and your fender ok? I can picture recoil and SMACK!
PostPosted: Mon Aug 03, 2009 6:11 pm
Ahhh, Necessity ...the Mother of invention :?
