It is currently Thu Sep 10, 2026 1:42 am
PostPosted: Mon Aug 31, 2009 7:06 pm
Ok, first off let me say love this forum, getting tons of useful tips and info to help get the old 14 turbo I picked up as a project back on the water. While replacing the rudder pins I noticed the hull is really worn were the pins go through. On the bottom there is a metal attachment that the pin goes through but nothing on the top. Is something missing ? If not what do you do to prevent this wear from getting worse ?
PostPosted: Mon Aug 31, 2009 8:06 pm
It's not really "wear" nor is it a structural part of the rudder system.
In fact, the class rules allow you to notch that hole out completely. Don't worry about it.
PostPosted: Tue Sep 01, 2009 5:48 am
wow, nice '85! original rudder cams and relatively no wear on the castings.
Sheet In...Max Out
www.fleet297.org
PostPosted: Fri Sep 04, 2009 10:10 am
Just check that when the rudder is in place that there is not too much play / slop in the housing. The bushing in the top pin guide had actually came out on mine, si I just replaced both top an bottom guides.
