It is currently Thu Sep 10, 2026 2:32 am
 Post subject: Rudders HELP!!!
PostPosted: Tue Aug 23, 2005 9:23 am
Does anyone know how to remove the rudder cams on the H14. They seem to be completely jammed and i can't remove the the pin.
PostPosted: Tue Aug 23, 2005 10:54 am
Drill the pin out and replace them with the rudder cam kit for H14/H16 in the catalog. I think it costs $25 US for both cams and two pairs of binding screws which will make cam removal much easier next time. This is worth every penny of the upgrade.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Wed Aug 24, 2005 5:17 am
I agree with hobie nick. This is well worth the upgrade and will take about 45 minutes of work.
 Post subject: Cams
PostPosted: Wed Aug 24, 2005 9:32 am
You can get the cams to open by using a small flat head screwdriver. Work it between the plunger and cam to force the plunger down. Once the plunger is disengaged, the cam will rotate. Then grease the cam indent and plunger!
Cam replacement FAQ: http://www.hobiecat.com/community/viewtopic.php?t=2174
Cams and rudder rake FAQ: http://www.hobiecat.com/community/viewtopic.php?t=467
