It is currently Thu Sep 10, 2026 12:18 am
 Post subject: new hobie 14 owner
PostPosted: Sun Oct 02, 2005 9:41 pm
Ok so i bought a hobie 14 becasue it kind of fell into my lap... i wanted something bigger but hey what can you do.. this boat came out of nowhere and had a good price on it... anyways my question... im a bigger guy eighing about 190 pounds... i want some more power... i found a used mast from a hobie 16... what would happen if i tried putting a larger mast and sail on my 14??? also i want to get a turbo kit.. anyone know a good place to find a turbo kit new or used.. i called the local sailboat shop around here and they gave me aprice of 800 bucks.... thanks for the help... thanks
proud owner of a 14 foot hobie cat...
PostPosted: Mon Oct 03, 2005 6:06 am
What ever you do, DON'T put a 16 mast on a 14. You will not be very happy with the results. The 16 mast itself is much heavier and the 16 sail is much larger than the 14. The hulls just can't take the extra weight. It is hard enough keeping the leeward hull out of the water as is. I have also heard about people wanting to put 16 beams on a 14. Again, they don't have the buoyancy and the geometry would be all off.
I'm in the 175-185lbs range and I don't have a problem on my 14. The Turbo makes it easier to tack, but it really doesn't add that much more to the boat. The cheapest way to convertyour boat is to get some good, used 16 rigging and cut it down to fit. Jibs come up every now and then on eBay as do the blocks. I got a great deal at Whirlwind sails last year when I ordered a bunch of jibs, so you might want to try there if you want an aftermarket. Of course, Hobie jibs are well made and class legal.
