It is currently Mon Aug 03, 2026 8:08 pm
 Post subject: What Year is My Boat?
PostPosted: Mon Nov 07, 2005 11:52 am
I just acquired a 197? H14 this weekend. I coudn't find a hull number on the boat. I looked on the transoms; no luck. Is there is somewhere else to look? The sail # is 1260. The panel second from the top is a light yellow. These are the original sails.
I think it's a 70's vintage because the main traveler has the v cleats on each end and the traveler itself is the kind with the plastic inserts for bearings.
Anyone have an idea of the year?
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Mon Nov 07, 2005 12:58 pm
Look for a 4 digit number stamped in the pylon. Probably the same as the sail. The boat is probably a 71. The number started going on the transom in 73 I believe. Matt ??
Pat Bisesi
Fleet 204 Syracuse, NY
PostPosted: Mon Nov 07, 2005 2:37 pm
I am pretty sure he's right. I have a '72 and it on the front port pylon. Older than Grandma's buckskin teddy.
Madcatter XXX? Good entertainment this year?? Regatta: $50 Lapdances: $25 :oops:
 Post subject: Serial numbers...
PostPosted: Mon Nov 07, 2005 3:55 pm
Serial numbers... there is a FAQ on it:
http://www.hobiecat.com/community/viewtopic.php?t=1155
PostPosted: Wed Nov 09, 2005 2:29 pm
I checked the numbers on the forward pylons. They read 1460. Now that I have found the serial number, and I know it is pre 1973, does anyone know what year? When did production begin on the H14's? Thanks for the help.
Nick
Current Boat
In the market
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Wed Nov 09, 2005 2:43 pm
Production began in July of 1968.
Fleet 297
PostPosted: Sat Sep 23, 2017 6:03 pm
I just picked another Hobie 14. Boat number 5852, located on the forward pylons.
Anyone have an idea what year it is? I know it is probably older than 1973.
Mike Hensel
'86 Hobie 18, '93 Hobie 14, '80 Hobie 14(restso in progress)
Wind in your sails, water in your shoes, great day!
PostPosted: Sun Sep 24, 2017 6:47 am
The new numbering system came into use in 1973 (it was a new federal law that standardized hull numbers like car VINs). 5852 is one of the higher numbers I've seen, so my guess is that it's a '72.
PostPosted: Sun Sep 24, 2017 6:59 am
Thanks Matt, I knew about the VIN requirement, I was curious about where 5852 fell in the production order and about what year.
So 1972 makes sense to me. I seem to be a magnet for these things, every time I look for a part on Craigslist, I find a whole boat to buy.
I'll end up with enough to have my own start :D
Mike Hensel
PostPosted: Wed Oct 04, 2017 10:20 am
Hi - I am new to Hobie ownership . I have a Hobie 14 and from following these posts I think I know it was built in 1979;
(the serial number on both hulls is CCMB6691M79A-R). This boat has the dolphin striker so does that make it a Turbo model?
Also re. the serial number : what does the B stand for? and the R at the end?
Thank you
PostPosted: Wed Oct 04, 2017 5:00 pm
Likely "Replacement" hull.
1979
