It is currently Thu Sep 10, 2026 12:40 am
 Post subject: Hobie dimensions
PostPosted: Thu Mar 30, 2006 11:48 am
What are the dimensions of the tramp frame on the 14 as i am designing a righting system and need the measurements because i cannot get to my boat at the moment.
Thanks guys
 Post subject: RE: Hobie dimensions
PostPosted: Sun Apr 02, 2006 3:12 am
The frame is 1.88 m wide and 1.68 m long. Measures were taken about in the center of each corner casting. Width has been measured on the rear bar.
Should you need to compute the momentum needed to right the boat, I have also weigthed relevant pieces:
Code:
Piece           Weight/Kg   Pounds
Starboard hull       28.1   61.95
Port hull            32     70.55
Mast total (2 pcs)   13.7   30.20
Jib, forestay, etc    4.3    9.48
Floating baloon       1.1    2.43
Main (dry) and Boom   8.4   18.52
For the same reason you might need to know that the baricenter of the mast is at 3.12 m from its base.
Please post pictures and results of your work if it works well.
Thanks,
Fabio
