It is currently Thu Sep 10, 2026 1:00 am
PostPosted: Fri Apr 21, 2006 10:30 am
Can I use 3/8 without drilling out the holes in the corner castings?
 Post subject: 3/8"?
PostPosted: Fri Apr 21, 2006 12:06 pm
3/8"? Can't imagine using 3/8" line. It is too large and does not turn through the grommets well. We sometimes us 3/8" bungee, but that is different. 1/4 is all you need, but if you are convinced... use a short piece of 1/4 or 3/16 at the end to pass through the corner casting, or drill away!
PostPosted: Mon Apr 24, 2006 6:36 am
Hey,
I am going to take the 1/4 out of mine and replace it with bungee so the tramp says tight instead of becoming loose. If you have line bungee is the way to go if you want to keep your tramp tight.
Mark (H-14)
PostPosted: Mon Apr 24, 2006 9:50 am
I don't like to use shock cord on the tramp since it streachs constantly. IF you want a tight tramp to keep your boat more rigid you should use a low streach line like Dacron and tighten it every once in a while.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
