It is currently Thu Sep 10, 2026 12:18 am
 Post subject: dangerous?
PostPosted: Mon Jun 26, 2006 2:12 pm
hi to all...
finally i have finished to arrange a 9mq (i think 96 sqf) touse into my h14...
i have used an old windsurf mast and do the pulleys like the hobies spi.
it can be dangerous for my cat...
i have fear to broke my shroud and demast....
wich is the best wind speed to use it?
thanx for all and sorry my english...
max
 Post subject: Spinnaker?
PostPosted: Mon Jun 26, 2006 3:54 pm
Spinnaker?
Light air. The boat is pretty tough. I would be you will capsize before damaging it.
PostPosted: Tue Jun 27, 2006 5:59 am
thanx matt...
just another question,light air is maximum 10 knots or something plus?
it is a simmetrical spi so what is the best way to use it ( the angle with the wind)?
sorry maybe are stupid questions but i'am a newbie in this world...
i plaied just ice hockey :)
thanx again and again sorry my english
PostPosted: Tue Jun 27, 2006 8:19 am
Depends on the sail cut and whether it fits the boat correctly. Optimized spinnakers can be used closer to the wind (closer to 90 degrees wind angle). Most spinnaker use is down wind to 45 degrees from straight down wind.
Wind speed? 12-15 knots is the upper end for comfortable use.
 Post subject: ok
PostPosted: Tue Jun 27, 2006 12:53 pm
perfect...now i have a good start point to do the job...
i have finished all the hardware,i'm just workink into the snuffer system....
where i can found a draw of the spi\snuffer configuration?
i think that i'll to close the jib during the spi use....
i'll post some pix when i have finished the work.
thanx
max
PostPosted: Fri Jun 30, 2006 4:37 pm
Matt
Is that sailing angle in relation to the wind, true for the Tiger also?
Cheers
Alan
