It is currently Wed Sep 09, 2026 7:29 pm
 Post subject: H14 mast rotation
PostPosted: Mon Jul 22, 2013 2:51 pm
Obviously my mast base is quite worn - should I also replace the step??
THANKS
 Post subject: Re: H14 mast rotation
PostPosted: Tue Jul 23, 2013 9:06 am
I would replace both. New castings are matched shapes. We updated them in 2004. More beef at the stops. Better contact surface angles for more mast rake.
PostPosted: Tue Jul 23, 2013 9:47 am
Thanks - is the same parts as for a 16 - or are they different
PostPosted: Tue Jul 23, 2013 9:56 am
Step for the H14 depends on age of the boat. Newer ones may have a Dolphin Striker? The step would be drilled for the post.
20200011 H16 / H14 Turbo Step Casting (drilled and tapped / threaded)
10170011 H14 no striker Step Casting
10640011 H14 Mast Base
PostPosted: Tue Jul 23, 2013 10:01 am
If I wanted the option to make it into a Turbo (in the future) - I should go with the 16 with the hole for the Dolphin then?
thank you
PostPosted: Tue Jul 23, 2013 11:57 am
There is a casting post and cable-type conversion kit for that. Upgrading to the Post and striker rod would be problematic...
I'd go the original step and then add the conversion kit which rivets a casting type post below the step. Then a cable runs from side to side.
