It is currently Wed Sep 09, 2026 6:24 pm
 Post subject: Sail threading
PostPosted: Mon Jul 29, 2013 12:25 pm
My H14 mast has a "flared" area where the sail threads. I am having trouble keeping the sail in the track while threading. I thought my H16 had an actual cutout for the sail. Anyway is there a method or add-on threading devices that will work with the "flared" mast?
thanks
 Post subject: Re: Sail threading
PostPosted: Mon Jul 29, 2013 1:33 pm
Due to the amount of luff curve on a catamaran sail... nothing available with thread the sail in while you only pull on the halyard. You need to help it into the slot.
From the sail hoist FAQ:
Raising the mainsail of a Hobie can be more difficult than need be.
Several factors can cause the mainsail to be difficult to hoist:
Dirty luff ropes and luff tracks. These can be cleaned with soapy water and a scrub brush. If you want to use a lubricant, keep away from oils and waxes that can attract dirt. Use a dry silicone spray. Most all Hobie sails now have a Teflon threaded bolt (luff) rope to ease the hoisting effort.
Battens and sail shape. The battens stiffen the airfoil shape of your sail. Over tensioning of the battens can cause a couple of problems. Luff protector caps can be forced against the mast and cause drag when hoisting. The battens also force the sail shape into a curve. The luff curve (seen when laying the sail out on the ground, as a large arch) is typical to Hobie Cat main sails. The sails "airfoil" shape is mostly created by the miss-matched mast bend and luff curve of the sail. The luff curve is more than the likely mast bend and when the mast is straight (while hoisting) the difference is dramatic. This luff curve going up the straight mast can cause significant drag and hoisting problems when done incorrectly.
Outhaul. Be sure the outhaul is fully released before hoisting.
Hoist Technique:
Keep the batten tension to a minimum. Hoist the sail slowly, while feeding into the mast opening. When the sail gets about 3/4's of the way up, begin aggressively feeding at the bottom opening and reduce the amount of halyard effort. If the halyard is pulled tight when the sail is not being fed into and up the track, you will have problems. The sail luff will pull taunt and the curve shape will bind in the (straight) mast track. Lower the sail slightly and begin feeding again.
The best way to feed the sail is to stand in front of the mast and reach around either side to "sandwich" the sail between two hands (above the feeder opening) and push the sail up the track. Pull with the halyard, only the slack created, then feed again. If the sail binds, lower slightly and begin feeding again. This technique can be done by one person, but is certainly easier with two working together. It is VERY important that the person on the halyard only pulls the slack up the mast and does not get ahead of the feeder.
Locking the Hobie 14/16/Getaway halyard:
Once the sail is fully hoisted (be sure that the sail is fully inserted into the feeder). Pull the halyard forward of the mast by 3-4 feet. Hold the halyard on the centerline of the mast. Pull hard and hold the tension while bringing the halyard into the mast. Release the halyard tension and see that the sail remains fully hoisted. This seats a small bead, in the halyard, under a two finger prong "hook" and the top of the mast. If the sail slips down when downhaul tension is added, repeat the final hoist technique again. Be sure the bead is clear to pass the hook before pulling tension on the halyard.
To release... fully release the downhaul and outhaul. Partially feed the sail up the luff track. Hoist with the halyard to the top till it stops, hold... pull the halyard line forward 3-4 feet away from the mast, ease the halyard to lower the sail.
PostPosted: Fri Aug 02, 2013 5:06 am
You might try this. http://www.murrays.com/mm5/merchant.mvc?Screen=PROD&Store_Code=MS&Product_Code=50-80100501&Category_Code=
PostPosted: Sun Aug 04, 2013 5:46 am
It's also available from your favorite Hobie dealer as part number HC 80100501.
Mark Van Doren
H14T Fantasia #47787
San Juan 28
PostPosted: Sun Aug 04, 2013 10:22 am
Can anyone confirm that this will work with the H14 mast that has just a flare in the mast guide - no cut out like on a H16?
thanks!
PostPosted: Mon Aug 05, 2013 3:08 pm
Hand feeding is the answer. "Feeders" help, but are not the cure. They can also cut and tear, so ... I prefer to advise as described in my FAQ.
