It is currently Fri Aug 07, 2026 3:39 am
 Post subject: Jib Height and Mast Rake
PostPosted: Fri Jul 01, 2016 8:52 pm
Hey folks,
I was looking for some advice reguarding my Turbo. Using a chain plate extention between the jib and the furler, I recently raked my mast far enough to make my sheet go nearly block to block. This has left my jib rather high, which from what I've heard is sub-optimal.
Will it really make a difference to put the forestay extention above the pigtail and lower the jib 8 inches?
Also, since raking my mast so severely, it has stopped rotating on its own or with any ease. I do have a teflon cup in my mast base and it rotated without fail before being raked.
Any input would be appreciated.
Thanks a lot,
-Sam Mc
Hobie 14 ('70s)
Hobie 14 Turbo ('70s)
PostPosted: Sat Jul 02, 2016 1:05 pm
I'm not an expert on the subject, but from what I've seen and experienced, if you're going block-to-block on a 14, then you're probably raked back too far (assuming you're using low profile blocks). The guys that I see racing (non-turbo 14s) always seem to have about 6-8" between the blocks when fully sheeted. It's not rigged like a 16 where you want as much rake as possible.
PostPosted: Sat Jul 02, 2016 3:49 pm
I have the adjuster above the swivel, I think it makes a difference. I find it easier to keep the tell tales flowing on the back side of the main - but that is my only benchmark.
I also had mast rotation interference and had to back off the rake to allow rotation. I started investigating a new mast step. It is the same as a H16 step which, I assume, allows more rake.
PostPosted: Mon Jul 04, 2016 7:38 pm
I hear about some guys putting multiple Teflon cups or even bottle caps in the mast base to allow rotation with more rake. Has anyone here tried this?
Hobie 14 ('70s)
PostPosted: Fri Jul 15, 2016 7:08 am
I have the "permanent" Delrin chip with nub installed on my 14
and it is a noticeable bit thicker than the teflon chips
but..as srm stated, I sail uni and we don't go block to block
you can always file on the aft side of the step casting (too mimic newer) if you have interference
1984 H16 "Mister Rogers"
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
