It is currently Thu Sep 10, 2026 1:18 am
 Post subject: Bow tangs
PostPosted: Mon Feb 05, 2007 3:33 pm
Anyone know how the bow tangs (I believe thats the name for them - the s/steel part which the bridle wires are attached to on the hulls) are fixed to the hulls. There are 4 screw or bolt heads. I have a concave on one hull under the tang and it's not too solid, so I want to reinforce it before the tang gets ripped completely out in a gust. Are they screws or bolts. I presume they can simply be removed, holes epoxyed and then refitted? Any advice would be great.
Hobie 14 Turbo, based in Marlborough Sounds, New Zealand
PostPosted: Mon Feb 05, 2007 4:58 pm
There is a small square plate of aluminum laminated within the bow. 1/4 inch thick and slightly larger that the 4 screw hole pattern.
PostPosted: Mon Feb 05, 2007 7:38 pm
Thanks Matt. Can I presume the plate is glassed into to bow and so will not fall loose when the bow tang screws are removed? I gather this is the case as it would be easier from a manufacturing point of view?
PostPosted: Mon Feb 05, 2007 7:39 pm
Matt, just re- read your reply and see that you mention it is laminated in so please ignore the previous question.
Cheers
