It is currently Tue Aug 04, 2026 12:24 pm
 Post subject: Hull stern damage
PostPosted: Mon Aug 10, 2020 3:46 pm
My '89 H14 project has very enlarged holes in the top of hull where the rudder pins go through the top of the hull on both sides. There doesn't seem to be any bushing at all. The gudgeons are in good solid shape.
Were there ever bushings on this years rudder?
Any ideas on how to repair this enlarged hole damage?
I've ordered new stainless rudder pins to replace the one nylon (flexible) and one fiberglass pin.
Does anyone know how to upload pics onto this forum so that the damaged hull holes can be viewed? (not super techy)
Thanks in advance
Image Image
'89 H14 'Jaws'
'85 H16
 Post subject: Re: Hull stern damage
PostPosted: Mon Aug 10, 2020 4:17 pm
Images FAQ: https://www.hobie.com/forums/viewtopic.php?f=18&t=8574
PostPosted: Mon Aug 10, 2020 8:59 pm
I don't think that the hole in the fiberglass is intended to bear any load in the rudder system. It's just there to allow access to the rudder pin for installation and removal. I copied the link for the following video at the point where you can see the hole that I believe you are talking about. The complete video is very worthwhile if you are going to do the rudder service yourself.
https://youtu.be/7jfn8f93XiQ?t=342
PostPosted: Tue Aug 11, 2020 3:25 am
Thanks Matt!
I have been watching a lot of JB's video's for all sorts of work. Very helpful.
Had to laugh at the "simple" instructions for pics to be uploaded to this forum. Still working on that... LOL
Haven't figured out how to get my IMgur pics to here...
Image Image
'89 H14 'Jaws'
'85 H16
PostPosted: Thu Aug 13, 2020 4:07 am
Stern damage, maybe from broken pin riding high?
Image Image
'89 H14 'Jaws'
'85 H16
PostPosted: Thu Aug 13, 2020 12:13 pm
Does this type of gudgeon require bushings?
Image Image
'89 H14 'Jaws'
'85 H16
PostPosted: Fri Aug 14, 2020 5:46 am
The gudgeons take all the load. As long as they’re solid and undamaged, I would not be concerned about this. Use a coarse flat and/or round file to clean up the damaged area and remove any fiberglass that may be contacting the rudder casting. Then brush on a small amount of polyester or epoxy resin to seal the exposed fibers.
