It is currently Sat May 04, 2024 12:57 am
PostPosted: Tue Mar 30, 2021 6:53 pm
I just got a Hobie 14 Turbo that will be a project. The one thing that I could not find out about is on the mast. Just above the warning label there are a pair of D rings (one on either side of mast) and I don't have a clue what they are for and could not find any mention of in the assembly manuals. Not sure if one can add photos on this board if needed.
PostPosted: Thu Apr 01, 2021 10:20 am
You may place photos on imgur. Once uploaded click on an image and imgur will give you some link options. Choose the size thumbnail you want to use (options under the list of links) and then copy the "Linked BBCode (message boards)" and paste it into your post.
Definitely not "standard issue"
1984 H16 "Mister Rogers"
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Thu Apr 01, 2021 3:05 pm
Maybe for a jib sheet tangle preventer. Bungee from striker up to a d ring then the other and down to the other side / striker rod. A triangle. Keeps sheets from getting down in the mast base area. Just a guess though!
PostPosted: Wed Apr 07, 2021 1:41 am
Thanks, I figured it was something that was added as I couldn't find it in any of the manuals or pictures. Simply a D ring on each side about the line of the mast sticker with the flat in a bracket so they can move up and down. Thanks for the input.
