It is currently Thu Aug 06, 2026 6:39 am
PostPosted: Wed Aug 18, 2021 12:45 pm
Hello,
My son was sailing our 1998 H14 and the boom cracked into two pieces.
I've looked on Ebay and Craiglist and can only find a couple of used ones and they are more expensive to ship than buy.
Has anyone figured out a way to maybe "splint" the boom?
I have seen (on Youtube) methods of fixing Sunfish cracked booms but they are shaped such that you can use chain-link fencing top rails to create the splint.
For the H14, I would have to figure out a way to split it with something C-shaped or U-shaped
Just throwing a dart here to see if someone has encountered and solved this in the past (but will not hold my breath)
Thank you!
PostPosted: Wed Aug 18, 2021 5:32 pm
Wow, never heard of a boom just breaking in half.
I don’t know about splinting it. I would look for a replacement - the Hobie 16 uses the same extrusion as the 14 (only longer), so don’t limit your search to only the 14. I think you will have a lot more luck sourcing a used 16 boom. Then you just need to cut it to length and install the block hanger in the right location.
PostPosted: Wed Aug 18, 2021 5:42 pm
where are you located?
Mike Hensel
'86 Hobie 18, '93 Hobie 14, '80 Hobie 14(restso in progress)
Wind in your sails, water in your shoes, great day!
PostPosted: Wed Aug 18, 2021 6:02 pm
I have come across some used H16 booms but still run into the shipping costs
I’m in the Raleigh area of North Carolina
PostPosted: Sun Aug 29, 2021 7:34 am
I’ve got a spare old 16 boom (two bails) that is surplus. I’m in Delaware. Always happy to help a fellow Hobie sailor, so if you can figure out a way to get it to you, it’s yours. Let me know.
H16 2002 "Islands" Sail No. 107432
PostPosted: Sun Aug 29, 2021 12:46 pm
Thank you very much for the kind offer!
I was able to buy an H16 off of Craigslist somewhat locally and will cut it down
Thanks again for the offer!!
PostPosted: Mon Aug 30, 2021 11:20 am
I have a 14 boom that is in good shape. Let me know where you are and we'll see if It makes sense to get it to you.
