It is currently Mon Aug 10, 2026 7:35 am
 Post subject: Judy Roughton Mardis
PostPosted: Fri Aug 26, 2022 9:24 am
I am replacing the drain plug pieces (don't know what it's called) for my Hobie 14. They are cracked and letting water in even with the plugs screwed in. Do I use epoxy or a gasket to seat to the hull?
 Post subject: Re: Judy Roughton Mardis
PostPosted: Fri Aug 26, 2022 3:31 pm
You are talking about replacing the plug's housing right?
A liberal amount of Silicone in and around the hole then push the housing in and add the two screws. Don't over-tighten the screws.
PostPosted: Fri Aug 26, 2022 3:37 pm
Yes, that’s exactly what I have. Thank you so much for clearing that up for me.
