It is currently Mon Aug 10, 2026 2:48 am
PostPosted: Sun Sep 25, 2022 12:52 pm
I went to look at a standard Hobie 14 today, which is in great condition, sails well and which I would like to buy, but I cannot work out the age of the boat. There is no VIN plate attached but the following letters and numbers are stamped on the stern of each hull: FR HCC 02 F 900.
The boat has a brand new, but unnumbered Hobie Cat mainsail, so I don't even have the sail number to go on?
I know that the FR HCC part tells me that the boat was manufactured in France by the Hobie Cat Company, but the rest doesn't seem to conform to any of the standard HC identity number formats?
Any help to unravel the mystery would be appreciated?
PostPosted: Tue Sep 27, 2022 8:04 am
Never seen that sequence. Must be a European system? Where are you located?
PostPosted: Tue Sep 27, 2022 8:23 am
I'm in France Matt.
PostPosted: Tue Sep 27, 2022 8:56 am
Looks like some characters missing but the F900 at the end, if accurate, could indicate June 1999 manufacture of a 2000 model year.
Peter
2016 Hobie Oasis with Evolve v2 rudder mount, Sidekick ama kit, Mirage sail kit, Garmin echoMAP CHIRP 42dv, bilge pump
2007 Hobie Outfitter x 2 with Mirage sail kits, large rudder blades
PostPosted: Tue Sep 27, 2022 11:00 am
I'm in France Matt.
Euro VIN requirements would be different. Contact Hobie France for any guidance. [email protected]
PostPosted: Wed Sep 28, 2022 1:27 am
Thank you for the replies received so far. I have contacted Hobie Cat Europe based in Toulon, France and have received the following reply:
Hello
Your hull number should normally start with FR-HCE and not HCC
The 900 at the end of your hull nr means the boat was built in 1999 with a 2000 vintage
The letter F means that the boat was produced in July
Regarding the sail nr, it is impossible to confirm which one your boat originally had because the sail nr is not a means of identification of the said boat and that from the moment there was a change of GV, there is bound to be a new nr.
All HC14 mainsails supplied by Hobie Cat Europe have an original sail number.
I will post a photo of the mainsail if someone can tell me how to. I'm buying the boat from a bona fide Sailing Club, so am confident that everything is as original as possible given the boat's age.
PostPosted: Wed Sep 28, 2022 8:30 am
Image use FAQ: https://www.hobie.com/forums/viewtopic.php?f=18&t=8574
mmiller wrote:
Posting an image... Images must be hosted at a location on the internet. (Suggested site: imgur.com or flickr.com)
Check the image below. Right click on the image to see the copy image address popup option:
Image URL ends in .jpg or .png or similar.
Navigate to your image page. Right-click the image. This must be an image address (url) rather than a url to a page. Click the above image to test and look at options to copy the address (url).
Rather than a link to the page it was on. The address should end in something like .jpg or .gif
Use the buttons above the post text area to find the proper code.
Use [img]then%20the%20image%20url%20and%20click[/img] again.
Be sure to have the option " Disable BBCode " unclicked!
and you are done.
