It is currently Sun Aug 09, 2026 6:00 am
PostPosted: Tue Sep 17, 2024 6:49 pm
I'm using a H14 mast and boom on a home built trimaran. Where is the "Home position" for the boom/gooseneck on the mast relative to the mast extrusion base. I'm measuring for a set of custom fitted sails, and the home position is needed as a base for the luff, with additional positioning with the downhaul. Much obliged and thanks for any direct measurement.
PostPosted: Fri Oct 18, 2024 4:02 am
On a new sail, the gooseneck should easily go into the luff track opening, but some downhaul should be required to pull it down where it's completely inside the luff track itself.
Jerome Vaughan
Hobie 16
