It is currently Thu Sep 10, 2026 2:06 am
 Post subject: Baby Bob
PostPosted: Mon Aug 13, 2007 10:47 am
I have a very old style of mast (it is circular on top in order to make space for the halyard pulley) and when I tried to install a baby bob, I realized that I would be drilling through the halyard pulley if I drilled through the top of the mast. Putting the fasteners in would then result in me not being able to raise the sail. I still want to attach the bob, but I don't know how. The bob has the four small holes intended for attachment purposes. I was thinking about drilling through the mast lower down to avoid the halyard, then tying the bob on. Is this feasible? The halyard pulley has a hole through the axle that could also serve attachement purposes.
PostPosted: Mon Aug 13, 2007 11:00 am
Authorized Hobie Dealer
there should be mounting instructions in the package for a non comptip installation. there are 4 short I'd guess 1/4" screws, you drill and tap the masthead for them to insert, they do not go in deep enough to effect the pulley.
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
 Post subject: Re: Baby Bob
PostPosted: Sun Aug 30, 2009 10:29 pm
I just had that problem too. You lightly drill but be very careful not to drill through the pulley, just the metal, then tap it. Wasn't as hard as it looks.
PostPosted: Mon Aug 31, 2009 11:37 am
I just installed one on a 14 - no problme! Drill and tap 4x holes in the top cast piece. I used a #21 drill bit and I think 6x32 threads, as per the Baby Bob written instructions. Use 4x short SS machine screws (such that they are not long enough to contact the pulley for the main halyard), about 1/4" is good. You should be all set! Now I am adding the jib tracks and blocks to make her a 14T :) -glen
PostPosted: Mon Aug 31, 2009 12:39 pm
I just attached my Babybob last weekend.
You drill four holes in the mast head, but be very careful not to drill through the sheave (Pulley)
Next you tap the holes (10-32). I used two taps, a starting tap and then a bottoming tap as not to damage the sheave. You can get these at Sears.
The short scews are used to then mount the float.
1977 Super Sunfish (sold)
1979 Hobie (sold)
2008 Hobie 16 (sold)
2023 Hobie 16
John
