It is currently Thu Sep 10, 2026 12:27 am
PostPosted: Mon Aug 27, 2007 7:49 am
Hi all. I bought a Hobie 14T about a month ago, and have sailed it a few times and it is awesome. Now that I am becoming a better sailer I would like to go solo. Only problem is I need 2 people to raise my mast since my current mast base is broken. The hole where the pin goes is broken off of the mast base. What I currently do is have one person at the mast base and use all of their weight to hold the mast base down in place as I lift the rest of the mast up. I have just ordered a new H14 mast base, and would like to know how I should go about replacing my current one. Do I have to seal it up with something since I do not have a mast float (baby bob)? Is there anything that I should watch out for?
Here is the part I am talking about: 10640011
http://www.hobiecat.com/support/images/ ... s/141b.jpg
Here is a pic I drew of my current mast base:
http://img503.imageshack.us/img503/8611/mastbasear6.png
PostPosted: Wed Aug 29, 2007 1:14 pm
miller would know the best, but as i recall from the two I've replaced, i simply just drilled out the rivets (but take a lot of care here, because you dont want to widen those holes), and then knocked off the end lightly with a mallet and large screwdriver.
however, the first one i took off would not budge and even with reccomendations from jeremy of heating it up a little with a torch to melt away the glue, i ended up just taking out the trusty old hacksaw, and cutting through the entire mast base just below the seam with the mast. it was a great workout, but hopefully you dont have to do it.
And yeah I would seal it up if you can, because the 14's turtle so easily, and i do not have alot of experience, but i have learned that making sure your mast is airtight is very important.
(there should also be a foam plug about 6 to 10 inches inside though, so it shouldnt be that important to get the bottom end sealed, so long as the head is sealed.)
hope this helps
Peter Scranton
'14 Tandem Island "Awesome"
'03 Windrider Rave "Menage a Trois"
