It is currently Thu Sep 10, 2026 12:40 am
PostPosted: Fri Jun 13, 2008 8:41 am
What is an acceptable weight for a 14 (non-turbo) and what is the best method for weighing the boat?
Thanks!
PostPosted: Fri Jun 13, 2008 6:45 pm
Anything close to the class minimum of 240lbs would be preferred.
You can weigh the boat with two bathroom scales, one under each hull and add the total. Find a smooth flat surface and protected from the wind. Don't forget to include all of the rigging and required equipment.
PostPosted: Fri Jun 13, 2008 6:55 pm
I agree with you on the "preferred" close to minimum weight, but...I've been hearing those are very rare boats and an "acceptable" weight may be closer to 255-265. (I haven't weighed ours yet).
What do you think John? What does your weigh?
Sheet In...Max Out
www.fleet297.org
PostPosted: Sat Jun 14, 2008 11:00 am
What is a good weight for each hull on its own?
PostPosted: Mon Jun 16, 2008 4:26 pm
That would be a good question for mmiller to answer.
PostPosted: Mon Jun 16, 2008 7:43 pm
My NEW boat only weighs 269. HA!
PostPosted: Tue Jun 17, 2008 6:52 am
"NEW" to you, right? And what year is it? I'm almost afraid to weigh my '82, built like tanks you know and solid as a rock, probably weighs comensurate as well. :roll:
Sheet In...Max Out
www.fleet297.org
PostPosted: Tue Jun 17, 2008 7:13 am
My OLD boat (this white one) was a 1972. My new one, with the white hulls and blue decks is much newer. 1973. I was 7 when this boat first hit the water (and I am old now......) but its hard and straight and it cost $250. Whattayado?
