It is currently Thu Sep 10, 2026 10:43 am
 Post subject: Getaway Hull scratches
PostPosted: Sat Apr 15, 2006 4:39 am
Any tips on repairing poly' hulls on the Getaway. Is there a suitable filler and did i read somewhere that these hulls cannot be painted. If so what is the best method of finishing. I have several battle scars on mine up to about 1/25" deep and 6 " long.
Regards,
OmallyCat
Dave B
 Post subject: Repairs
PostPosted: Sat Apr 15, 2006 8:49 am
Likely the best is to leave it alone, but you can trim off the loose material and then buff. There is no filler material that will work.
PostPosted: Sun Apr 30, 2006 8:56 am
I read with dismay that there is no suitable filler for the hull. I have a brand new Getaway. Sailed it 2X. Last week a freak storm with 60 mph wind picked it up, snapped the anchor line and threw and it into the dunes. Amazingly, the only damage is a scrape in the hull that includes a pin-sized hole. How can I repair this hole? What do I do to get my new boat seaworthy? Thanks!
PostPosted: Mon May 01, 2006 6:12 pm
I don't know if anyone has tried it but this looks like it could work. http://www.urethanesupply.com/step3b.html
PostPosted: Mon May 01, 2006 6:14 pm
this page says it worked on a wave, I would think it would also work on a getaway.
http://www.urethanesupply.com/kcwelder.html
PostPosted: Tue May 02, 2006 5:33 am
Be careful. If i remember correctly the wave hulls are not cured the same way a Getaways hulls are cured. I believe teh getaway has the outer skin of the hulls crosslinked which will prevent most tings from bonding to it. I don't think the wave hulls are like this. I would do a test somewhere hidden and not structurally important to see how well it works.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
 Post subject: Cross Linked
PostPosted: Tue May 02, 2006 9:20 am
Both the Wave and the Getaway have Cross Linked Polyethylene outer skins.
If there is a pin hole that is leaking, it could be filled with an epoxy material I think. The patch should be a plug that expands into the inner foam layer as a mechanical bond. You would need to hollow out a small area. You also may be able to weld (melt) some of the inner foam to plug the hole.
PostPosted: Mon May 08, 2006 5:39 pm
What about using a PTEX stick used for repairs on Ski Bottoms. Easy to handle and control. I have fixed many a gouge on my skis.
PostPosted: Mon Aug 07, 2006 1:32 pm
I am trying marine grade GOOP. Wish me luck.
 Post subject: Re: Cross Linked
PostPosted: Sun Nov 13, 2011 10:39 am
What is the "inner" side then? Seems to me someone could insert something into the hull as a "backing", then use whatever sticks to the "non-outter" material, and also fill the thickness of the hull.
PostPosted: Thu Nov 17, 2011 10:05 am
Check out G-Flex Epoxy from West Systems.
I used it on a roto-molded kayak with good luck.
They saw a kayak in half and glue it back togeter with this stuff on the site. http://www.westsystem.com/ss/g-flex-epoxy/
1980 H16
PostPosted: Wed May 23, 2012 1:14 pm
has anybody used this on the waves of getaways with success?
Hobie 16 - Boomer Sails
Matrix 5.5
PostPosted: Wed May 23, 2012 2:21 pm
You could get an Old Town Canoe repair kit:
http://store.oldtowncanoe.com/products/ ... lex_Repair
Even a skid plate if you land often on a rough beach:
http://store.oldtowncanoe.com/product/0 ... 974e7c0619
But the skid will slow you down, it's not a beautiful patch.
Marc...
