It is currently Mon Aug 24, 2026 8:14 am
PostPosted: Fri Oct 03, 2008 4:44 am
Thanks again guys, I really appreciate the info. I am so glad I found this website. I look through it all the time and cant believe all the helpful tips. GIT ROT it is for me !!!!!!!!!
Thanks again,
John Yaeck
PostPosted: Fri Oct 10, 2008 4:03 pm
For a large(4-5 ft. long) delam repair on the side of the hull can you do it all at once or is it better to do it in smaller sections letting it cure in between?
PostPosted: Fri Dec 19, 2008 5:02 pm
If you drill through the second layer and can't get it clogged, is it possible to make the outside hole slightly larger so you can slip in a patch that is slightly larger than the inner hole? I have heard that to get the foam out of the way you can use an allen wrench on a drill and insert the smaller end into the hole. Drilling it will reem out a small area to access second layer. On a side note, we use drill stops for carpentry that tighten onto a drill bit with a set screw. It works great for banisters and other detail work.
I'm about to do this repair to my boat, so I have been asking around. There are good ideas on this site
