It is currently Tue Aug 25, 2026 12:11 am
 Post subject: Super Glue Repair Patch
PostPosted: Fri Jul 11, 2008 1:25 pm
I found this quick patch sheet material (Glass reinforced polyester ) and purchased it to give it a try. All I can say is Wow. Great stuff!!! Sold with Super Glue branding as "Permanant Patch"
Permanent Adhesive Patch
Anchot-Tite Patch is a very easy-to-use UV or sunlight activated repair patch. It is fiberglass-reinforced and creates long-lasting repairs. Can be cut to size and molded to a desired application shape. Will not rot or rust and can be drilled or tapped after cured. Accepts paint in 1 hour and can be sanded to a smooth finish.
Click for PD sheetWorks best on:• Water tanks
• Flashing air conditioning units
• Personal watercraft
• Engine Parts
• Metal
• Concrete
• Roofs
• PVC pipes
• Boats
• Fiberglass
• Wood
