It is currently Fri Sep 04, 2026 4:43 am
PostPosted: Wed Jun 04, 2003 5:20 pm
Could someone point me toward some Hobie 18 Main Block Threading Directions?
Thanks in advance.
m
PostPosted: Wed Jun 04, 2003 5:55 pm
Authorized Hobie Dealer
It depends on what type of block set up you have. http://www.hobiecat.com/support/pdfs/36_37.pdf this is a link on how to run a 6:1. I hope this helps if not let me know and I'll try to find a way to help.
Brad Stephens
http://www.sunjammers.com
850-235-2281
Authorized Hobie/Vanguard Dealer
Panama City Beach, FL
PostPosted: Wed Jun 04, 2003 7:20 pm
Brad,
Thanks for the reply. I have a mixture of stuff. I bought the boat used and got a Harken triple block with cleat.
In addition, I bought a stock factory set up which was sent to me as a Seaway triple upper block connected to a single block with anti reverse and cleat.
Reading the material you referenced, would it be advisable to take the Seaway triple upper block (2 1/2 inch) and combine it with the Harken
(3 inch) w/anti reverse and cleat to create a 7:1 set up? Am I following this correctly to tie off to an empty boom bail?
Mike
