It is currently Sat Aug 22, 2026 10:44 am
PostPosted: Mon Jul 27, 2009 3:16 pm
I am finally getting around to fixing my H-18 transom. Wind pushed my parked hobie into a fence and the rudder broke out a chunk (most) of the transom. I cleaned and cut, and have only about 1" or less of a lip right left and bottom.
I put in an access port, and I have my fiberglass materials ready to go.
My question is: Should I try and emulate what was there before, with fiberglass/thin foam/fiberglass? or should I just build it completley with fiberglass? It's not that much foam in that layer, maybe less than 1/4 inch.
I realize with solid glass there will be a slight weight factor. I am also wondering if it will be stronger, or perhaps, without the foam, more brittle and weaker? Maybe the glass/foam/glass gives it more flexibility?
My plan was to put in a thin piece of foam, like builder's blue-board, to match the core, and fiberglass on both sides, inner and outer.
I am not racing this boat, just having fun, but I would like to have my repair stay in place.
Am taking photos. Will post as repair continues.
Thanks.
PostPosted: Tue Jul 28, 2009 5:40 am
Just be aware that polyester resin attacks (dissolves) styrene foam.
Not a problem if you're using epoxy.
Divinycell foam is what's used in the original construction.
Divinycell from Jamestown Distributors
PostPosted: Tue Jul 28, 2009 8:26 pm
I was wondering where that thin piece of foam I so carefully cut went!
Thanks,
A
