It is currently Sat Aug 22, 2026 8:55 am
PostPosted: Thu Sep 10, 2009 5:36 pm
I am missing the cleat for the jib tie down that is located on the mast port side, holes are already there. does any one recommend just using stainless steel screws to attach the cleat instead of rivits (sp).
PostPosted: Fri Sep 11, 2009 1:17 pm
Not unless you can get inside the mast with backing washers and nuts... so no, rivets are the way to go.
