It is currently Sat Aug 22, 2026 4:04 am
 Post subject: Tiger Hull Repair
PostPosted: Fri Oct 16, 2009 1:12 am
We discovered this damage at the weekend by chance. The area in the photo is in the starboard hull looking back from the forward inspection hatch with the dagerboard case on the left.
The damaged area shows the inner layer of grp broken and peeled back partly. This was repaired from the outside some time ago but we didn't realise it had gone through to the inner layer.
Obviously knowing it's there now we'd like to repair it but access is a problem since theres no way to reach it through the inspection hatch. Is it possible to take the deck off on a Tiger or do I have to cut a hole in the deck to reach it(not ideal since any repairs to the deck will be visable in the non-slip)?
 Post subject: Re: Tiger Hull Repair
PostPosted: Fri Oct 16, 2009 4:26 am
The best way to do this is to re-do the repair from the outside.
Read "This Old Hobie - Blind Hole Repairs" in the May/June 08 issue of the HOTLINE - www.hobiecat.com/hobieclass
PostPosted: Fri Oct 16, 2009 8:16 am
Replacement decks are available if you wanted to go that route as well.
