It is currently Sun Aug 16, 2026 7:37 am
 Post subject: Failed A-Frame on Bravo
PostPosted: Tue Jul 26, 2011 1:16 pm
Hey Everyone,
Was sailing my Bravo in about 12 mph winds when the front post on the A-frame supporting the mast failed at the lower rivets. Fortunately, was up wind from the house and able to sail the boat in, while the mast was canted at about a 45 degree angle.
Upon inspection, it appears, corrosion on the bar that holds the A-frame forward post appears to be the culprit. Looks like galvanic corrosion where the rivets held the post to the lower rod weakened the rod and it snapped off.
I know I have seen a post on how to repair this, but can't find it. Anyone have any thoughts?
View of the carnage attached.
2001 H16E (European Boat) Sail #108348 Cabo
Club Wave
1991 H14T (Crushed by a Tornado)
2006 Bravo (sold)
1986 Hobie 16 (sold)
1981 Hobe 16 (sold)
1980 Hobie 14 (sold)
PostPosted: Tue Jul 26, 2011 2:33 pm
Should be able to remove that part by unscrewing it from the molded insert - and replace it with a new piece (looks like it just snapped at the base from age and fatigue...not likely from just that one use in 12 mph winds - that happened over time) - Hopefully you can tweak the frame back into shape - but that might need replacing too.
- just order the parts from any Hobie dealer, the illustrated parts guide is located here: http://2010.archive.hobiecat.com/suppor ... _Bravo.pdf
For a dealer call toll free 1800hobie49 to order
PostPosted: Tue Jul 26, 2011 5:28 pm
Thanks for the help. I will try to remove it tomorrow. I agree that age and stress was the most likely culprit...not the wind in this case. Although, its mostly age/exposure as the boat hasn't had that much use
As for the A-frame...I will do my best to straighten it. Will probably have to remove it from boat so as not to damage connections. I have a dealer I can use for parts.
Thanks!
Club Wave
2006 Bravo (sold)
1981 Hobe 16 (sold)
