It is currently Sun Aug 16, 2026 7:37 am
 Post subject: Sail Repair
PostPosted: Fri Jul 22, 2011 12:02 pm
 Post subject: Re: Sail Repair
PostPosted: Fri Jul 22, 2011 12:38 pm
Can it be repaired? Yes.
Is it worth repairing? Not likely.
I'd say the sail is totalled. That would be a time consuming and expensive repair to do properly. You'd likely be looking at several hundred dollars for a loft to fix. And its a highly loaded part of the sail so a simple patch will not hold up. You'd be putting money into a sail that's well past its prime. It would be much better to put that money towards a more recent used sail.
