It is currently Fri Aug 14, 2026 8:03 pm
PostPosted: Wed Dec 28, 2011 5:19 pm
I'm considering doing a bottom job on my yellow hulls and don't know exactly how to do it. I have a big thing of West System 105 epoxy and hardener that I would like to use. I don't really want to have to spray gelcoat on the repair area though. What would it look like over the yellow hulls if I just left the fiberglass repair unpainted? Anyone have pictures or past experience?
Zach
PostPosted: Wed Dec 28, 2011 8:12 pm
The problem with epoxy for an exterior repair (gel coat issues aside) it that it turns from yellow, to amber, then brown when exposed to UV (sunlight)
You can mitigate this somewhat by mixing pigment with the resin - but the color won't be stable. You could have a perfect match the day you did it, then a month later, it'll be a different (browner) color.
Given that the bottom job is on the bottom, you could probably get away with using the WEST 105 as long as you were really careful not to get any on the outside flat of the hull and minimize the coverage on the inside. Masking tape and drapes are your friends.
