It is currently Fri Aug 14, 2026 10:54 am
PostPosted: Sun Feb 05, 2012 10:23 pm
HI, I need some tips on how to remove the tiller arms from the H 17 castings..
I got one out after putting the casting in a vice like workmate table and drilled a large hole thru the tiller where I could put a big Screw driver in and Twist the Tiller arm..It Finally came out...
The Second one Won't budge and twisting broke my Table that was used as a vice.
Any tricks??? Bigger Vice and Bigger lever????
Mark Milam
Lousiana
PostPosted: Mon Feb 06, 2012 10:35 am
Mark Milam
Lousiana
try PB Blast. let it soak. Are you from Spring TX?
Jeff
1986 Hobie 18 #13031
PostPosted: Mon Feb 06, 2012 12:50 pm
Hi
Been soaking for a day now. I'm frm Lafayette
