It is currently Wed Aug 12, 2026 9:34 pm
PostPosted: Sat May 26, 2012 7:45 pm
What is the best way to remove gel coat from a hobie 16 deck with anti skid. I would image if you sand it, it would remove the anti skid texture?
Patrick
Hobie 16
Hobie Getaway
PostPosted: Sun May 27, 2012 4:33 am
It is impossible to remove the gelcoat without removing the non-skid texture. The texture is molded into the gelcoat. If you need to remove the gelcoat, then the only method is to sand it away.
If you want to later replace the textured gelcoat, then you have to mold it back in when you apply the new gelcoat.
PostPosted: Tue May 29, 2012 9:51 pm
Well that answers my question, and makes perfect sense. Thanks!
Patrick
Hobie 16
Hobie Getaway
PostPosted: Wed May 30, 2012 6:34 am
Check out "This Old Hobie" articles in the Hobie Hotline magazine on non-skid repair.
Nov/Dec 2008 and Jan/Feb 2009
http://w1dm.com/projects/HOTLINE/Hotline.html
Jonathan
'85 H16 __/) 87468 Tidal Wave
PostPosted: Fri Jun 01, 2012 3:01 pm
That looks good, So I will need to lay down some new grip it appears...
Patrick
Hobie 16
Hobie Getaway
