It is currently Mon Jun 15, 2026 2:34 pm
PostPosted: Sat Apr 25, 2015 3:13 pm
Gday guys and girls
having just recently attained a 1974 hobie 16 i have just now noticed that the forward stbd pillar that goes from the deck into the hull is loose , moving up and down about 4 inches. before i cut into the hull i would like to know could anyone help me with more information on repairing this problem. i first thought if i drill a hloe through the pillar close to the deck and then put a pin through the fiberglass over the pin this would work but htinking on the force needed to hold this i soon relised that maybe not. but i am not sure how they are originally held in place, does anyone have photo's or suggestions?
thanks in advance.
chris
PostPosted: Mon Apr 27, 2015 10:16 am
4 inches? That's a lot of motion. I'm not sure if that can be fixed.
The front pylon (that's the proper term), is part of the deck layup, then when the hull/deck are joined, it rests in a "shoe" that bears against the hull. Here's a cross-section of the assembled hull/deck:
In your case, it sounds like not only has the shoe become unbonded from the hull, the pylon has become unbonded from the deck. This is a major repair, and not really cost effective on a 40+ year old boat.
PostPosted: Mon Apr 27, 2015 11:24 am
I would recommend you download the Sept/Oct 2009 Hobie Hotline magazine. That issue included an article that specifically discussed the repair procedure for fixing a broken pylon shoe.
PostPosted: Mon Apr 27, 2015 8:06 pm
Thanks sm
I am going to repair this, it did not cost me much.
Could you give me a link to issue to download, very much appreciated.
Great photo. It looks like a few beers an a bit of bog(fibre with resin) should be able to fix it if I cut a hole in the inside, then up a bit of wood with more bog where the hole is then put the hole pice backover. Should work.
Cheers
Chris
PostPosted: Tue May 05, 2015 9:11 am
http://www.w1dm.com/projects/HOTLINE/Hotline.html
