It is currently Wed Aug 05, 2026 5:32 am
 Post subject: mast repair
PostPosted: Fri Jun 19, 2015 11:19 am
Is there any repairing a mast that has snapped at the fiberglass junction ? Or should I be looking for a new mast ?
 Post subject: Re: mast repair
PostPosted: Fri Jun 19, 2015 1:26 pm
The aluminum is intact? The CompTip broke at the joint?
A new CompTip is about half the cost of a mast.
PostPosted: Fri Jun 19, 2015 3:05 pm
Yes aluminum is intact
PostPosted: Fri Jun 19, 2015 4:20 pm
What model boat?
PostPosted: Sun Jun 21, 2015 5:58 am
I really not sure what year model, 1980's. It was recently restored.
PostPosted: Sat Nov 14, 2015 4:14 am
Would you like to share some pictures of your boats ?
PostPosted: Fri Mar 25, 2016 4:04 pm
Is it possible to remove the comp tip without destroying it? My boat blew off the trailer and the sail track on the comp tip is coming off, and it looks like it installs by sliding it onto the comp tip from the bottom...gee, I guess my real question is how to get the plastic sail track back on the comp tip.
PostPosted: Fri Apr 01, 2016 2:44 pm
It should be fairly easy if none of your parts were damaged. Thankfully there's no need to remove the comp-tip.....that's a much more difficult job. The track just snaps on.
From Hobie's H16 support page: http://static.hobiecat.com/item_attachm ... 151z52.pdf
It will help if all the lips and grooves are clean. Maybe even lube it with a little dishwashing soap.
Jerome Vaughan
Hobie 16
