It is currently Wed Aug 05, 2026 3:41 pm
PostPosted: Thu Jun 02, 2016 12:48 am
I am doing my first bottom job. Are the keels sanded enough? There seems to be some dark/black areas under the fiber glass in some areas. Do i need to sand down to there and remove? Any other advice based on the pictures?
https://www.facebook.com/daniel.burris. ... uploaded=7
PostPosted: Fri Jun 03, 2016 2:35 am
Just make sure it's roughed up really well using coarse sandpaper (80 grit). Then clean the surface with acetone before you start laminating the new glass. There's no need to aggressively remove the existing fiberglass unless it isn't well adhered (i.e., someone did a previous bottom job and the fiberglass from that job is coming off).
PostPosted: Fri Jun 03, 2016 7:41 am
Check this article out:
"The Bottom Job - This Old Hobie" by Rick Buchanan on pages 12 & 13 of the Sept/Oct 2008 Hotline.
http://www.w1dm.com/projects/hotline/08 ... OTLINE.pdf
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
