It is currently Thu Aug 06, 2026 4:26 pm
PostPosted: Thu Jan 19, 2017 3:19 am
Hello
I plan to transform my HC16
this will imply cutting and adding new tubes to the platform.
I have 2 option : welding but i am not sure the extruded aluminium is good for this ?
Milling blocs of Al which will adapt on the beam.
Does anyone knows if cad files of the cross sections of the beams cross and long section are
available somewhere ?
JD
PostPosted: Fri Jan 20, 2017 8:51 pm
No and no.
Welding will remove the temper from the aluminum - for small repairs, it's OK, but not for real structural work.
There are no CAD files that I know of for the extrusion section. You're probably best off just cutting a section and digitizing it.
