It is currently Mon Aug 31, 2026 9:48 pm
 Post subject: Hobie 21 taper pins
PostPosted: Sun Feb 01, 2004 12:15 pm
I have a problem with a hobie 21. The holes in the crossbeams, through which the taper pins pass, have become large and corroded. The taper pins are rendered ineffective, which allows a lot of play between the hulls and the crossbeams.
Any suggestions on a good fix for this will be much appreciated
PostPosted: Mon Feb 02, 2004 10:09 pm
Authorized Hobie Dealer
If you can get us some pictures I will try to help you out. What year is the boat?
Thanks,
Brad Stephens
www.sunjammers.com<------New Site!
Authorized Hobie/Vanguard Dealer
Division 15 Chairman
Panama City Beach, FL
PostPosted: Mon Jul 18, 2005 12:48 am
I also had this issue, good old wear and tear. Check the inside diameter of the holes and have a machine shop turn some pins for you. Make sure you allow enough threads to tighten the taper pins.
PostPosted: Mon Jul 25, 2005 10:05 am
I have a '88 21SE and am familiar with the pins. I think having those pins made, especially from stainless would cost $500+. I would suggest cleaning out the holes and welding them back smaller then re-bore to the correct size. You will probably have to remove the sleeves to avoid heat damage but they are easy to rivet back on if you remove them carefully.
