It is currently Sun Aug 09, 2026 12:26 pm
 Post subject: Bow tang screw fail
PostPosted: Mon Jul 29, 2019 10:16 am
I need help. A friend has a 17' Hobie boat ( i know nothing about sailing boats) and asked if I could help with a repair. from the little research I've done, it appears that the bow tang fastening screw has pulled out (center front, left hull). There does not appear to be any aluminium block as mentioned in some posts I've read. It seems this could be fairly easily repaired with epoxy and either tapped appropriately?
I'd like to help her out, and do it right, so I am very appreciative of all input. I have pics I can share, but I do not know how to post those on this forum.
 Post subject: Re: Bow tang screw fail
PostPosted: Tue Aug 06, 2019 4:22 pm
You have to post the photos on another site like facebook, then right click and copy image location. you past that info between the Img][Img that show up when you click it above.
Buxton
18' T16 Silent Lightning (16' T2 Hybrid)
11' H16 White Lightning
79' H16 Green Lightning
PostPosted: Wed Aug 07, 2019 9:08 am
Image FAQ: https://www.hobie.com/forums/viewtopic.php?f=18&t=8574
