It is currently Sat Aug 08, 2026 12:34 pm
 Post subject: Cracked rudder tops
PostPosted: Fri Aug 09, 2019 9:43 am
Was cleaning the boat yesterday (that'll teach me) and put some light pressure on the tiller and it just broke away from the rudder. The rear part of the rudder top, above and behind the tiller bolt hole, just broke away. There are plenty of ancient rudders lying around here in the OBX but they wouldn't be drilled right for my adjustable castings, so I trimmed the whole rudder top down by about 1.5" and redrilled holes. You can see the crescent-shaped part that broke off.
Didn't lose that much length.
Unfortunately the other side has cracks in the same place, so I will either be repeating this repair in the near future or shopping for new rudders.
'00 H16 #104691
Old Holsclaw trailer
My Hobie 16 pages
 Post subject: Re: Cracked rudder tops
PostPosted: Tue Aug 01, 2023 4:02 pm
So it seems that I probably meant to fix that other cracked one when I got home, and of course totally forgot. Sailed the rest of the '19 vacation, all of the '20, '21 and '22 vacations, and then yesterday I was out for a solo cruise and when the rudder kicked up on a shallow spot it broke out that same back part, on the crack lines that I showed from 2019.
I took it next door to Hatteras Watersports to borrow a saw and drill, and the bottom line is that while I was at the beach with my family the owner just fixed it on his own using my other cut-down one as a template. Looks beautiful. I'm back in business. Didn't even have the chance to take a photo.
While I'm doing shout-outs about rudders, I can't neglect to mention that last year as I was leaving the beach I stopped at the current OBX fiberglass Hobie dealer to buy a new main halyard and scored a nice set of 1st-gen EPOs from Hardy. It's actually deliberate that I don't have them with me, because I intend them to be my deep-water rudders. No sense tearing up EPOs on the sand bars on the Pamlico Sound.
'00 H16 #104691
My Hobie 16 pages
PostPosted: Thu Feb 26, 2026 10:24 pm
First of all, what are you doing that the rudders break the same exact way????
Secondly, look back at your pictures to see the circular scratch marks from your rudder castings scraping against the rudders. I would say that those should not be there, but 99.99999% of all Hobie Cats have them. However, you don't have to have them, and before you put the EPOs on the boat, you should know how to prevent the scratches. I think you can get rudder shims from several places. If you can't find them, you can make your own with the lids from butter, sour cream, Cool Whip, cottage cheese, and other dairy products. Cut the lids into 3" diameter circles and punch a hole in the center. The hole should be the diameter of bolt going through the rudder. Do this for all the holes. Before you do anything with your spacers, drop the rudders to inspect the gap between the rudder and the casting at each bolt. The gap will be different on either side of the rudder and different for every bolt hole. Slip some of the shims into the gap until you can't get any more in. You will have to have at least one on each side of the rudder at each bolt. When you can't get any more shims in the gap, take one away and that is your shim count for that side on that bolt. Pull the bolts, one at a time to install the shims. It's a little tricky to get them all in, but this is going to be worth the trouble. The rudder should be packed in between the casting when you're finished. Pack the upper and lower castings before you tighten any bolts. When you tighten the bolts, everything will be different. Tighten them until the rudder supports itself at about 45 degrees when you lift the tiller arm to release them. The rudder should not fall all the way down, but you should be able to easily push it down into place and pull it all the way back up. Getting these shims right might just fix whatever it was causing the rudders to break. I'm not familiar at all with the H18 rudder setup, but I do know the fix for the scratches on the rudders.
When you install the EPO blades, the shims will likely be different due to the different thickness between the stock and the EPO blades.
PostPosted: Thu Mar 05, 2026 6:23 pm
Sailing - generally beam reach or higher - after the rudders have kicked up in shallow water. Getting back to the beach. The sound is shallow for a LONG way out. LOTS of weather helm, even if I'm luffing the main.
'00 H16 #104691
My Hobie 16 pages
PostPosted: Thu Apr 16, 2026 4:59 am
You probably have all this figured out by now, Anton, but...
1. Gen1 EPOs aren't gonna break like the old plastic ones...they are tough as nails. You are probably lucky that the old ones lasted as long as they did.
2. Scratches? We don't care 'bout no steenkeeng scratches.
3. I would never tighten a rudder bolt so much that it squeezes the casting in toward the blade...that's just asking for trouble. Snug 'em up and shim if you must. However, on my Gen1 EPOs, fiberglasss racing rudders, and my EPO2s, no shims were ever really needed. In fact, I've seen cases where the heads on the Gen1s were so fat that the castings needed some milling just to make them fit. (Maybe someone had previously over tightened those rudder bolts?)
The EPOs are such good, tough, durable rudders that I would not hesitate to run them full time, sandbars or not. For cosmetic wear they can be overcoated with appliance epoxy paint (UV protection). If they wear enough to show fibers, a thin coat of epoxy (with graphite additive) then the topcoat. They're tough I tell ya'.
Jerome Vaughan
Hobie 16
PostPosted: Wed Jul 01, 2026 2:48 pm
Hey Jerome,
I would have them as my "Sound rudders" because they're shorter now. Years ago a guy (Ron?) from PA showed me his shortened H18 rudders that he used only when he was down at the OBX. Just the 1.5" that came off these seems to help. And FWIW I cleaned/lubed/adjusted the cam system and it worked like a dream last week at the beach. Next up is to drill out and replace the frozen spring and rake adjusters.
The EPOs will get filled and drilled, then get a coat of clear. I'll use them when I go to the York River... plenty of water there. Definitely going to drill them so they can go well forward.
'00 H16 #104691
My Hobie 16 pages
