It is currently Tue Aug 18, 2026 3:14 pm
 Post subject: Supercat 2" mast ball
PostPosted: Mon Oct 24, 2022 3:02 pm
A friend has a Boston whaler supercat an he needs a 2" mast ball. He thinks it's made of teflon and I drew a 3d model to have it printed. Teflon/PTFE is not available, will nylon 12 suffice? What are these usually made of? Thanks in advance.
PostPosted: Mon Oct 24, 2022 4:44 pm
Delrin.
PostPosted: Tue Oct 25, 2022 7:56 am
Thank you, do you think nylon will suffice?
PostPosted: Tue Oct 25, 2022 8:34 am
Delrin is harder. Nylon may deform under load.
PostPosted: Tue Oct 25, 2022 9:30 am
You can get a 2” Delrin ball from McMaster Carr. You would just need a machine shop to drill and tap it with the correct threads. Or if you have access to a drill press, you could probably do that yourself.
https://www.mcmaster.com/balls/system-o ... l-plastic/
PostPosted: Tue Oct 25, 2022 1:19 pm
great, thank you!
PostPosted: Thu Oct 27, 2022 12:25 pm
Get in touch with Aquarius Sail, they are the curators of the Supercats.
https://www.aquarius-sail.com/
